Dell 19" tölvuskjár
thorsteinn1
Póstar: 43
Skráði sig: Þri 15. Des 2009 18:36
Dell 19" tölvuskjár
Pósturaf thorsteinn1 » Þri 15. Des 2009 21:57
Lýsing
19" Dell Ultra Sharp 1908FPc DVI Blu-ray 720p Rotating Monitor meðUSB 2.0 Hub & HDCP Support
Var keyptur í september í fyrra. Vel farinn í topp ástandi. Upphafsverð: 20.000 kr.
Mynd: http://www.geeks.com/largePic_All.asp?I ... B-unit.jpg
Tækniupplýsingar:
General Features:
# Color: Black/Silver
# 19.0-inch TN (Twisted Nematic) LCD Display
# 1280 x 1024 maximum resolution
# 5:4 aspect ratio
# 800:1 contrast ratio
# 300 cd/m2 brightness
# 5 ms response time
# 160°/160° (horizontal/vertical) viewing angle
# 16.7 million colors, 72% color gamut supported
# 0.294 mm pixel pitch
# Built-in 4-Port USB 2.0 Hub
# Height adjustable stand with tilt, swivel, rotate and built-in cable management
# Wall mountable: 100 mm x 100 mm hole configuration
Connectors:
# 15-pin VGA
# DVI-D dual link with HDCP
# One (1) USB 2.0 upstream
# Four (4) USB 2.0 downstream (2 rear, 2 side)
# Audio DC12V jack (for Dell Soundbar, sold separately)
Power Specifications:
# 100-240V ~ 50/60Hz, 1.5A
Unit Dimensions:
# With stand: 14.5-19.25 x 16 x 7.5-inches (H x W x D, approximate)
# Without stand: 13.25 x 16 x 2.0-inches (H x W x D, approximate)
Regulatory Approvals:
# FCC
# CE
# NOM
# C-Tick
# BSMI
# CCC
# cULus
# MIC
# NEMKO
# VCCI
# GOST-R
# TUV
# TCO'99
# WEEE
# Safety Mark
thorsteinn1
Póstar: 43
Re: Dell 19" tölvuskjár
Pósturaf thorsteinn1 » Mið 16. Des 2009 16:45
búið að bjóða 15.000 kr fer líklega á því ef enginn býður betur.
