[TS] Antec P182B Seldur...
Nothing
Póstar: 467
Skráði sig: Mið 17. Sep 2008 23:09
Pósturaf Nothing » Fim 24. Sep 2009 23:37
Er að gæla við hugmyndina að selja / skipta kassanum mínum út.
Kassin er í toppstandi, vel með farinn og alles.
# 11 Drive Bays:
- External 4 x 5.25"; 1 x 3.5"
- Internal 6 x 3.5" for HDD
# 7 Expansion Slots
# Cooling System:
- 1 rear 120mm TriCool™ Fan (standard)
- 1 top 120mm TriCool™ fan (standard)
- 1 lower chamber 120mm TriCool™ Fan (standard)
- 1 front 120mm fan (optional)
- 1 middle 120mm fan (optional) to cool the VGA
# External fan control on the rear panel for the top and rear fans in the upper chamber
# Compatible Motherboards: Mini-ITX, microATX, Standard ATX
# Double hinge door designed to open up to 270°
# Rubber grommeted ports on the rear for liquid-cooling tubes allow you to mount external liquid-cooling hardware
# Front-mounted ports provide convenient connections:
- 2 x USB 2.0
- 1x IEEE 1394 (FireWire®, i.Link®)
- Audio In/Out (HDA & AC'97)
# Cable organizers behind motherboard tray minimize cable clutter
# To optimize performance of your P182 the choice of your power supply is crucial. Antec strongly recommends choosing from our Signature or TruePower series
# Dimensions:
- 21.3" (H) x 8.1" (W) x 19.9" (D)
- 52cm (H) x 21cm (W) x 51cm (D)
# Net Weight:
- 30.9lbs
- 14kg
Svona kassi nýr útúr búð kostar kringum 35þ.kr
Verð: Tilboð / Skiptum við annan tölvukassa.
Síðast breytt af Nothing á Þri 29. Sep 2009 00:21, breytt samtals 2 sinnum.
AMD 5800X3D | 2xAMD RX6800XT RED DEVIL (EK-Quantum Vatnskæling)| 64GB (4x16GB) G. Skill Ripjaws V 3600MHz | ASROCK X570 TAICHI RAZER | 1TB SAMSUNG 990PRO | Be quiet! Dark Base PRO 901
mercury
Póstar: 3458
Re: [TS] Antec P182B / Skipti á öðrum kassa
Pósturaf mercury » Fim 24. Sep 2009 23:49
snilldar kassi. mæli með þessum.
Glazier
BMW
Póstar: 2511
Staðsetning: Mosó
Pósturaf Glazier » Fim 24. Sep 2009 23:50
9.000 kr.
Allinn
Póstar: 459
Skráði sig: Fim 17. Apr 2008 18:22
Pósturaf Allinn » Fim 24. Sep 2009 23:53
10 þús og tek hann um mánuðarmót
chaplin
Póstar: 4352
Pósturaf chaplin » Fim 24. Sep 2009 23:57
Nothing
Póstar: 467
Pósturaf Nothing » Fim 24. Sep 2009 23:59
daanielin skrifaði:10k eða viewtopic.php?f=11&t=24741 + 8k.
daanielin er með hæsta boð - semsagt kassan + 8k
emmi
Póstar: 1903
Staðsetning: Reykjanesbær
Pósturaf emmi » Fös 25. Sep 2009 07:03
12k
JohnnyX
Póstar: 1442
Pósturaf JohnnyX » Fös 25. Sep 2009 11:00
Leita að einhverjum sérstökum kassa? Ákveðin stærð?
corflame
Póstar: 678
Skráði sig: Fim 15. Apr 2004 20:05
Staðsetning: Keyboard central
Pósturaf corflame » Fös 25. Sep 2009 11:05
Ekkert powersupply?
Nothing
Póstar: 467
Pósturaf Nothing » Fös 25. Sep 2009 11:08
JohnnyX skrifaði:Leita að einhverjum sérstökum kassa? Ákveðin stærð?
Nei bara kassa til að hafa íhlutina í til að byrja með, annars ef þetta verða beinharðir pening, þá býst ég við að ég tek einhvað úr geymslunni.
corflame skrifaði:Ekkert powersupply?
Nei bara kassinn, Það er Antec P190 sem fylgir PSU með Semsagt 550w og 650w, Antec P182 kassarnir koma ekki með PSU.
goggi79
Póstar: 19
Skráði sig: Þri 22. Jan 2008 00:40
Pósturaf goggi79 » Fös 25. Sep 2009 11:42
12500 kall í brakandi Brynjólfum
Core 2 E8400-3.6Ghz@1,250v * DDR2 Exceleram 5-5-5-15 4x2048 * ASUS P5ND 750i * MSI 8800GT * FX Extreme HDAudio * Samsung Syncmaster T240HD 24" * Windows 7 Ultimate 64bit * Aflgjafi 560w High-Power * Kassi ATX m/LCD skjá * ca 2 Terabite HDD
JohnnyX
Póstar: 1442
Pósturaf JohnnyX » Fös 25. Sep 2009 11:44
goggi79 skrifaði:12500 kall í brakandi Brynjólfum
og einum Jóni Sigursyni?
Nothing
Póstar: 467
Pósturaf Nothing » Fös 25. Sep 2009 11:55
Goggi79 er með hæðsta boð...
chaplin
Póstar: 4352
Pósturaf chaplin » Fös 25. Sep 2009 13:36
10k og Antec kassinn..
emmi
Póstar: 1903
Pósturaf emmi » Fös 25. Sep 2009 15:00
15k
Nothing
Póstar: 467
Pósturaf Nothing » Fös 25. Sep 2009 15:22
Var að senda út PM til daaanielin um tilboðið hans, og ætla að taka því ég ætla í smá project með antec kassan hans. :8)
Ef hann beilar þá fer hann til Emma :wink:
Buzy84
Póstar: 1
Skráði sig: Fös 25. Sep 2009 21:10
Pósturaf Buzy84 » Fös 25. Sep 2009 21:13
Ef það sést ekkert á kassanum er ég tilbúin að greiða 16,000kr
Kv Óli R
Nothing
Póstar: 467
Pósturaf Nothing » Lau 26. Sep 2009 17:49
Buzy84 skrifaði:Ef það sést ekkert á kassanum er ég tilbúin að greiða 16,000kr
Kv Óli R
Ég og daaanielin erum búinir að ákveða skiptin, ég er bara að bíða sallarrólegur eftir að hann sækir þetta.
@ Buzy84: Ef daaanielin beilar þá á emmi fyrsta rétt, svo þú, Emmi fer á undan því ég var búinn að segja það áður en þú komst með tilboðið þitt, Stend við orðin mín :wink:
